Configures the route timeout period for RIPng.
| seconds | Specifies a time in seconds. Range is 10 to 3600. |
180 seconds.
If a router does not receive an update message from its neighbor within the route timeout period (180 seconds by default), the router assumes the connection between it and its neighbor is no longer available.
The configured value is rounded off to the nearest multiple of 10.
The following example sets the route timeout period to 120 seconds:
configure ripng routetimeout 120
This command is available on platforms with an Edge, Advanced Edge, or Core license. For licensing information, see the Switch Engine v33.1.1 Licensing Guide document.
